Drastic Difference in Static vs. Riks analysis
Hi All
in the files attached you see the results for the static and Riks analysis for a loading in the z direction =100 N , that have a drastic difference , I will have to do a buckling analysis on this model , but first for another reason I need to know that reaction results in different load cases , but for the analysis , for example for tension i tried both static general and Riks method , but the results have too much difference , as the riks stresses are so much higher than the static one , while I also don,t know that whether i should expect nonlinear behavior for this geometry , while the parts are orthotopic materil , the first one is the risk analysis with a 50 MPa result for a 100 N loading
i appreciate your attetion
RE: Drastic Difference in Static vs. Riks analysis
