loop over the node component/selected node, in which nodes numbers are not in sequence.
Hello, everybody
Is it possible to loop over the node component or the selected node numbers, in which nodes number are not in sequence.
Thank you a lot
wind
RE: loop over the node component/selected node, in which nodes numbers are not in sequence.
Use the NXTH function from *GET. Your script may look something like:
CODE -->
nsel,s,node,,.......             ! select the node set
*get,currn,node,0,num,min        ! get minimum node num in variable currn
*get,num_of_nodes,node,0,count   ! get num of nodes
! Create a loop to carry out some function such
! as finding the nodal x co-ordinate
*do,J,1,num_of_nodes
         ncx = nx(currn)
	*get,currn,node,currn,nxth   ! Get the node number in the set higher than currn
	node = currn
*enddo
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
You can also use currn = ndnext(currn) instead of the *get,currn,node,currn,nxth
*get,nmax,node,platei,count
*get,minno,node,platei,num,min
*dim,p1node,,nmax
n0=minno
p1node(1)=n0
*do,i,2,nmax
n0=ndnext(n0)
p1node(i)=n0
*enddo
*do,in,1,nmax ! start loop over all nodes in one plate
*get,xno,node,p1node(in),loc,x
*get,yno,node,p1node(in),loc,y
*get,zno,node,p1node(in),loc,z
dz = wopl*(b1*sin(pi*(xno-0)/a)+b3*sin(3*(xno-0)*pi/a))*sin(pi*(yno+375)/b)
n,p1node(in),xno,yno,zno+dz
*end do
Drej and Orel, Thank you two.
I combined what you two said, and write the above code, it works.
many thanks to you two.
cheers
