System Requirements and Upgrading NX
I have a laptop that runs NX 7.5 at an acceptable level. Should I expect this same hardware to run NX 9/10 as well or are the requirements becoming more demanding as new versions are released.
We are looking at upgrading a few components (like an SSD) in the laptop now and are questioning if it will be worth when we switch NX versions in a few months.
Specs:
Quadro 3700M
4gB of Memory
Core2 Extreme 3.5Ghz Processor
Specs:
Quadro 3700M
4gB of Memory
NX 7.5.5.4
TC 8.3.2
RE: System Requirements and Upgrading NX
NX 7.5/8.0/8.5/9.0
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If you are not running a 64 bit OS, upgrade that pronto. NX 9 and later will only come in a 64 bit version.
www.nxjournaling.com
How long with I expect this processor to be relevant with regard to NX. Is the program getting significantly more cpu intensive as newer versions come out? Also the same question for the video card as well.
NX 7.5.5.4
TC 8.3.2
64-bit OS is a must
16GB of memory
Ben Loosli
That being said, generally speaking, any 'professional' level laptop sold in the last few years, particularly if it was marketed using terms like 'portable workstation', you should be OK.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Specs
Xeon E5-2620 2.0ghz
8 Gig ram
dual NVIDIA Quadro K2000 2gig ram on each
125 gig ssd
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.1.3(Testing)
If you can think it it can be modeled
