Zig Zag transformer temperature
Is there a temperature formula for zig-zag transfomers?
RE: Zig Zag transformer temperature
Any help will be greatly appreciated.
How warm the bank actually becomes when placed in service will of course be determined by the sum of the heat generated due to losses plus the value of the neutral return current as determined by how well balanced the loads are across the phases of your system; the less neutral return current there is the less heat will develop from that source.
CR
However, one has to know the winding conductor cross section area since current density [J] has to be calculated priorly.
Darrell Hambley P.E.
SENTEK Engineering, LLC
