NX7.5 Assembly Load Options "to save files on one network drive or two?"
We use two network drives at my place of employment, one is a common shared drive and the other is a engineering only drive.
Some of our customer parts (3D Models) are stored on the common drive, but our internal assemblies are stored on the engineering drive.
I continually have to change my Assembly Load Options when loading an assembly that contains customer suppplied parts.
Would it be easier and less option changes if these files lived on the engineering drive?
Hope you can help,
Thanks!
Hope you can help,
Thanks!
RE: NX7.5 Assembly Load Options "to save files on one network drive or two?"
A possibly easier method would be to use the "as saved" load option.
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
"D:\directory_a\..." where the "..." means search subdirectories.
I.e Do not enter "C:\..." because NX will search the entire disk. ( until it has found the files)
Tomas
