Selected Hole Center
Hi!
I developed a macro that select a hole! then make a point center of that hole!!
reference_piece1 or reference_piece2 in the 2 cases I have a problem with update! :Hole.1 the element has no associated geometry must recreate the geometry!
any suggestion please!!!!!!!
CODE -->
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim selection1
Set selection1 = productDocument1.Selection
Dim InputObjectType(0), Status1
InputObjectType(0)="Hole"
Status1=selection1.SelectElement2(InputObjectType,"Select un trou",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
Set oHole = selection1.Item(1).Value
Dim partDocument1 As Document
Set partDocument1 = documents1.Item("part1.catpart")
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridShapeFactory1 As Factory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("Corps principal")
Dim sketches1 As Sketches
Set sketches1 = body1.Sketches
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim hole1 As Shape
Set hole1 =shapes1.Item(nom_trou)
Dim sketch1 As Sketch
Set sketch1 = hole1.Sketch
Dim reference_piece As Reference
Set reference_piece1= part1.CreateReferenceFromObject(oHole)
Set reference_piece2= part1.CreateReferenceFromObject(sketh2)
'Set reference1 = Selection1.Item(1).value
Dim hybridShapePointCenter1 As HybridShapePointCenter
Set hybridShapePointCenter1 = hybridShapeFactory1.AddNewPointCenter(reference_piece 1 ou 2??!! )
hybridBody1.AppendHybridShape hybridShapePointCenter1
part1.InWorkObject = hybridShapePointCenter1
part1.Update th problem with update!! reference_piece1 or reference_piece2 in the 2 cases I have a problem with update! :Hole.1 the element has no associated geometry must recreate the geometry!
