Low specific gravity Flame retardent compound
I am new to this forum and look forward to learning and sharing knowledge with everyone.
I am currently working on a project where the lower specific gravity of the compound the better. This job is a rubber coated fabric (both sides) and has a fire retardancy callout. The fabric is a nylon/Kevlar that is RFL treated (currently for neoprene but if needed that can be changed). The compound I am currently using is a neoprene containing Hydral 710, antimony oxide and a chlorinated paraffin oil and has a gravity of 1.40. My problem is, this job has a very low overall weight callout and the compound along with the fabric limits me to a very small amount of compound on each side of the fabric (calendared on). This small amount is barely enough to cover the fabric and does not give me much leeway at the calendar. I would like to create a compound that has a lower specific gravity (cannot change the fabric other than the type of RFL coating). The fire retardency callout is 8 sec max to extinguish with 2 sec max afterglow. I will be trying an RFL treatment that is supposed to be fire retardant but unsure what it will do to my adhesion and how much weight it will add to the fabric (which would affect the amount of compound I can put on if it goes higher).
Type of rubber used is open. Cost is not a limiting factor (at least not at this point). The lower the gravity the better. Fire retardant type is also open, there are no restrictions as far as toxicity, etc. at this point.
Thank you for your help.
RE: Low specific gravity Flame retardent compound
Tom Jablonowski, TSE Industries, Inc.
www.tse-industries.com
I have also thought about an SBR but looking for an alternative to ATH due to its high gravity and need for a heavy loading. My other thought, if I went with SBR and ATH fire retardant, would be to add PVC for the chlorine content. But I still feel I would end up with a high gravity.
