Flatten a curved "thicken" on NX 6
I have attached a view of a curved "thicken" with holes that I am trying to produce a fflat pattern to dimension. I have tried the "Flat Pattern & Flat Body" command in "Sheet Metal" to no avail. I have also tried using "Unwrap" but it will only unwrap a cylinder or cone, of which this is NOT.
I would appreciate any other options to try.
Thank You,
Mike
Thank You,
Mike
RE: Flatten a curved "thicken" on NX 6
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
http://www.eng-tips.com/viewthread.cfm?qid=252267
http://www.eng-tips.com/viewthread.cfm?qid=329615
