NX8.5 motion simulation. "Marker is not associated with geometry" warnings
I am trying to perform a motion simulation in NX8.5 (Recurdyn solver). I am wondering how trustworthy the data is going to be, because I keep getting the following warnings for every joint in my simulation except the 'fixed' joint (I have ten joints):
base_to_balance_link Warning: I marker is not associated with geometry
base_to_balance_link Warning: J marker is not associated with geometry
I thought that making a new simulation by checking the box "Environment > Component-based simulation" would get rid of these warnings, but it did not. My simulations seem to run okay, and I can get force data graphs with the "load transfer" feature.
Are these warnings something I should be concerned about? If yes, then how do I fix the problem?
