Reference Book of U.S. Drawing Standards?
I am searching for a reference book to help get a Japanese manager (and engineer) up to speed with U.S. drawing standards and best practices. We have already given him a copy of ASME Y14.5M-2009 for understanding GD&T, but he wants a better understanding of best practices for different types of drawings. For example, from what I have seen in my career it is very common to create hydraulic hose drawings which reference all of the hose and hose end specs as well as the SAE J1754-2 characteristics(hose curvature, clocking angle, etc.). It has also been common in every company I work for to use multi-sheet drawings, BOM tables, exploded views, and cross-hatched section views.
The reason I am looking for this book is that our counterparts in Japan utilize a book for drawing standards which goes against pretty much everything that is standard in the United States and this manager has realized that we need to fix this problem. For example, the Japanese engineers are not allowed to use multi-sheet drawings and it is against the rules to use BOM tables (all part info is in the balloon), and cross section views. This makes for a drawing that is extremely difficult to understand and leads to tons of errors and problems.
Anyone know of a book that would help in this situation that would also build on ASME Y14.5M?
RE: Reference Book of U.S. Drawing Standards?
There are also books that attempt to put it all together in one place, such as the Global Drawing Requirements Manual (concise) or the Genium Modern Drafting Practices and Standards Manual (huge).
Personally, I prefer to follow the standards themselves directly.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
The standards & even the 2 DRM's he mentions don't have everything though and in my opinion are weak on details for assembly drawings in general.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Most of the 'meat' is in it's supporting standards. I've previously posted lists of which ones I use most frequently if it's of help.
As you convince your bosses to "Americanize" their approach to drafting, introduce actual standard books:
You've already introduced them to Y14.5,
"better understanding of best practices for different types of drawings: - ASME Y14.24
"multi-sheet drawings, BOM tables, exploded views, and cross-hatched section views" - ASME Y14.1, ASME Y14.3, ASME Y14.34
Also ASME Y14.8 for castings, ASME Y14.6 for screw threads, etc, etc.
If you still looking for "one thick book", ewh's suggestion still valid: Global DRM, or Genium. Just keep in mind that both of them stuck around 2008 and there is a lot of stuff happening since 2009 both in ASME and ISO worlds.
If not, can you provide a link?
There is also newer version of it around:
https://standards.nasa.gov/documents/detail/331514...
-Dalai Lama XIV
http://www.draftingzone.com/subscribe/
John H. Dunten, CD
Certified Drafter
