Mathcad BUG or....??!!
This is a screenshot (attached)
The result I was geting where suspicious so I started a calculation "by hand".
It seems that some values (formulas) dont update when I change the input parameters.
I wrote the same formula beside the original and the result were different as you can see.
Any idea what couses this?
RE: Mathcad BUG or....??!!
Which Mathcad version and which maintainance release?
Again - which version and maintenance release of Mathcad are you using? Current version is Mathcad 15 M030. (Prime being so deficient to that very high degree up to uselessness can't be considered a Mathcad version and guessing from your screenshot you are not using Prime).
I assume that autocalc is turned on (Tools/Calculate/Automatic Calculation)? If not, thats the problem.
You can recalc a single expression with F9 as opposed to CTRL-F9 for the whole sheet.
It may have to do with the inline evaluation. What happens if you do assignment and evaluation in 2 separate regions? Does the problem persist?
I also noticed that in the left region of your screenshot there is a mutliplication dot between the number and the unit while in the right one there is none - not sure at all if that has any meaning, though.
Anyway, the reason I was asking for the exact version you use is a bug which was not fixed until Mathcad 14 M030 (the last but one version of MC14 and the last we can recommend using as M035 had a severe bug).
From the release notes for MC14-M030:
"SPR 1437427 Fixes in-line evaluation to update display to match available value. "
Its seems that I have the "EVIL VERSION" wich is known for this bug.
V14 MO20
BTW, MC14 M020 wasn't that "evil", but the 14ers before are, suffering from real bad, severe bugs. That was the reason PTC decided at those times to give M020 to all customers for free, even those without maintainance.
Mathcad 15 F000 was originally planned to be Mathcad 14 M040, but then PTC marketing took over. So there is not that big change under the hood.
Find attached the release notes of the current MC15 M030, listing all bugfixes since MC14 M035. The bug in question is not listed as it was already fixed in MC14-M030. Can't find the release notes of MC14 M035 but you can google for them (as I did before) - its not a pdf but a couple of html pages. OK, found it at PTC here: http://www.ptc.com/WCMS/files/98347/en/Mathcad_14_M035_RELNOTES.HTM
TTFN
Many consider MC11 the best version ever. A good reason for this is Maple as symbolic engine instead of muPad.
