O-Let Welding
O-Let Welding
I know this topic has been beaten to death, as I've gone through pages of search results on the topic. I wanted to throw an application/proposed solution out to see if there might be something else I should consider.
1" Sch.40 SA106B pipe requires a 1/2" NPT connection on the side. GTAW, GMAW, and SMAW welding methods available.
-I've considered using Sch.80 pipe and backwelding a threaded Tee into place, but would prefer to not do so because the customer has been finnicky and would probably squash any backwelding plans.
-Using a half coupling was considered, but rejected for a small number of reasons.
-The (presently) prefered method is to weld a copy-cat Thread-O-Let to the pipe. I cannot claim to be a welding expert, but based on the information I can dig up, my proposed soultion is:
1) Clamp pipe near both ends into a length of unistrut and clamp the unitstrut in the middle (beneath where the o-let will be welded) into a bench vise, both to hold the member during welding and keep the pipe from bowing downward and spreading the sides of the unistrut.
2) Set welding machine to high end of amp range. I would leave the exact setting up to the welder since I'd rather they be able to make a good weld than sacrifice weld quality by specifying an amp setting they are not able to comfortably use.
2) Tack the o-let in place at the 12,3,6, and 9 o'clock positions (pipe axis along 12 to 6 line).
3) 1st/root pass in quadrants- From 1:30-4:30, 10:30-7:30, 1:30-10:30, and 4:30-7:30.
4) 2nd/cap pass in quadrants- From 12-3, 9-6, 12-9, 3-6.
5) Grind fillet weld to a flat finish.
One thing I'm not sure of is wait/cooling time between weld stitches and between passes. Any quick suggestions, or just the obligatory "hit the books" to figure it out? Are there other options I should consider to reduce weld distortion, or any changes to my proposed procedure that are obvious to those more experienced than I?
RE: O-Let Welding
RE: O-Let Welding
*Make d@*m certain that you do not exceede 1250°F in any spot while PWHT'ing.
RE: O-Let Welding
