Assembly drawing using Bill of Materials will not call out part number and description correctly
I want to thank everyone with sharing all you knowledge with me. Here is my next question from the rookie.
I have a assembly drawing, a block with three dowel pins two of one size and one is a different size. The Dowel pins belong to a table with many different sizes or is this called a famiy table and I did not create this table.
When I load the model into the drawing and bring in the Bill of Materials it shows Item 1 the block, item 2 Dowel pin qty 2 and item 3 Dowel pin qty 1 the issue is that the Bill of Materials in the part number and discription areas is calling both Dowel pins the same thing. How do I get the Bill of Materials to show what each Dowel pin is supposed to be called. In the Table the Dowel pins come from they are named correctly like M2X12 and M4X12
Thank you,
Jeff
Thank you,
Jeff
RE: Assembly drawing using Bill of Materials will not call out part number and description correctly
To make a BOM work, you must do two things.
- Add configuration specific properties to your parts that uniquely identify them.
- Add columns to your BOM that read those properties.
I strongly recommend an additional step. Make sure you can copy out of your BOM into your requisition form.Type once, only.
JHG
SWX Design Tables are very easy to use. Do yourself a favor and run through ALL the built-in tutorials (Help -> SolidWorks Tutorials), especially the ones relating to DT's.
- - -Updraft
