Create hybridShapePointCenter
Hi!!!
I'm having some trouble getting update to work the way I'm expecting it to.
so if anyone has a better understanding of the best way to use this method it would be appreciated,
th u :)))
CODE -->
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim partDocument1 As Document
Set partDocument1 = documents1.Item("part.1")
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim shapeFactory1 As Factory
Set shapeFactory1 = part1.ShapeFactory
Dim body1 As Body
Set body1 = bodies1.Item("Corps principal")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
Dim hybridShapes1 As HybridShapes
Set hybridShapes1 = body1.HybridShapes
MsgBox "selectionnez un trou"
Dim InputObjectType(0), Status1
InputObjectType(0)="Hole"
Status1=selection1.SelectElement2(InputObjectType,"Select un trou",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
nom_trou= oHole.Name
Dim partDocument2 As Document
Set partDocument2 = documents1.Item("part.2")
Dim part2 As Part
Set part2 = partDocument2.Part
Dim bodies2 As Bodies
Set bodies2 = part2.Bodies
Dim body2 As Body
Set body2 = bodies2.Item("Corps principal")
Dim sketches1 As Sketches
Set sketches1 = body2.Sketches
Dim shapes2 As Shapes
Set shapes2 = body2.Shapes
Dim hole2 As Shape
Set hole2 =shapes2.Item(nom_trou)
Dim sketch2 As Sketch
Set sketch2 = hole2.Sketch
Dim reference_piece As Reference
Set reference_piece= part2.CreateReferenceFromObject( hole2)
Set reference1 = Selection1.Item(1).value
Dim hybridShapeFactory1 As Factory
Set hybridShapeFactory1 = part1.HybridShapeFactory
Dim hybridShapePointCenter1 As HybridShapePointCenter
Set hybridShapePointCenter1 = hybridShapeFactory1.AddNewPointCenter(reference_piece)
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Item("Set géométrique.1")
hybridBody1.AppendHybridShape hybridShapePointCenter1
part1.InWorkObject = hybridShapePointCenter1
part1.Update so if anyone has a better understanding of the best way to use this method it would be appreciated,
th u :)))
RE: Create hybridShapePointCenter
Creates a new circle center point within the current body.
Parameters:
iCurve
Reference circle
Sub-element(s) supported (see
Boundary object): see Edge.
oPoint
Created point
in your code the reference is pointing to the Hole feature from selection. The reference for AddNewPointCenter is supposed to be a curve (or an edge).
my macro selects a hole then recuperates its diameter! then creates a center point!!
but if l try to work with curve or edge! i can't get the diameter!!!
so, is there another solution?
CODE --> CATVBA
Dim InputObjectType(0), Status1, activedoc, selection Set activedoc = CATIA.ActiveDocument Set selection = activedoc.selection InputObjectType(0) = "Hole" Status = selection.SelectElement2(InputObjectType, "Select a Hole", True) If (Status = "cancel") Then Exit Sub Dim oHole 'As Hole // you cannot dim object if you want to use GetOrigin Set oHole = selection.Item(1).Value Dim oHoleCenterXYZ(2) 'As Double // you cannot dim object if you want to use GetOrigin oHole.GetOrigin oHoleCenterXYZ ' objects are not dim but it works! MsgBox ("Selected hole name = " & oHole.Name) MsgBox ("Hole center x:" & oHoleCenterXYZ(0) & " y:" & oHoleCenterXYZ(1) & _ " z:" & oHoleCenterXYZ(2))indocti discant et ament meminisse periti
Look at this !
I will put all of it in FAQ... this is good!
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
