Pillow Bearing Needed
I am searching for a pillow block bearing that is similar to the UCP 314 FYH which withstands temperatures to about 500C of heat. Please refer me to the manufacturer as the current bearing I am using is the UCP 314 and it gets damaged every few weeks.
Thank you for you attention.
RE: Pillow Bearing Needed
http://www.graphalloy.com/html/pillow_block_.html
and
http://www.dodge-pt.com/products/bearing/sleeve/so...
@romke The problem is due to over heating. at temperatures of circa 500C. The bearing itself cannot withstand high temperatures. that is why I am looking for the ones which can withstand these high temperatures. It is located in the dryer.
