Crosshatch in detailed view
I'm using NX 7.5.5.4 and facing a issue with crosshatch in drafting.
When i placing a detailed view of a section view i notice that the crosshatch settings are the same.
I was suspecting that the crosshatch was also scaling up with the detailed view.
Now i know that i can make the detailed view independent but that's not what i want.
Does anybody knows a work around for this problem?
Ruud
Ruud
RE: Crosshatch in detailed view
I am not at work right now, but I think I got this right.
It is only that i don't want to make the detailed view independent.
I think it's just that the view's properties (in Style) will be independent of its parent view.
Are you sure that that's what you want, that is, "scaling up" the crosshatch settings?
I mean, this is what that would look like, but you would need to edit it to get that result:
But don't you think the image below looks better? I do, and besides, this is what you get for 'free' without having to mess with changing the 'Independent' status or editing any Settings:
But whatever, the 'Convert to Independent' option simply means that you can set the Display Settings to be DIFFERENT in the Deatiled View as opposed to the Settings used in the parent view. As for associative updates when the Model or the view boundary or location changes, that will continue to work irrespective of whether the detail view is 'Independent' or not.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
thanks for the information.
I sometimes have te problem that the angle of the crosshatch change when i make a detail view of a section.
Is there a setting for this or not?
Ruud
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
