ETABS Import Problem
Did a quick search, couldn't find anything, so here's the problem I am having.
Just installed ETABS v13.1.3, but I can't import any dwg or dxf files, always end up getting a dialog box with this message,
"Can Not Open File c:\xxxx\xxxx\xxxx.dwg"
I'm running AutoCAD 2014 on Windows 7 (32 bit)
Any idea how I can fix this please?
Thanks in advance.
RE: ETABS Import Problem
Maybe it has something to do with the patch you've used. Try to export a dxf file to see what comes up.
My Father taught me to never disown poor people!
Having the exact same problem...
Any fixes guys?
make sure the dwg/dxf file isn't opened in autocad
if it still wouldn't work, try reinstall autocad with all of its components
Yeah still didn't work. Any other fixes?
Export your DXF using version Autocad2000 (See Autocad/Option/Saving)
Retry to import your dxf
DWG files should work though?
Have they fixed this bug in the 2015 version?
2015 works fine for me. i think 14 will work too so long as u install all the components
Still getting this error in ETABS 2015. Does it need to be a certain AutoCAD file? As in 2007, 2010, 2014 etc?
Do DXFs work better?
I have the same issue.
I tried with several versions of autocad, doesn't work.
You need to have a full version of Autocad installed locally on your PC in order to be able to import DWG's direct into ETABS.
if you dont, then your only option is to use a DXF.
if the file will be imported is already open.You can take this messages.
1-save in DXF format
2-close the file
3-than import
