Double Tee flange to IT beam connection
Typically on double tee construction I have provided an attachment to the supporting beam or bearing wall with a connection centered on each stem. I have a precast manufacturer who likes to use a single connection from the flange centered between the stems. any thoughts?
RE: Double Tee flange to IT beam connection
