Help with macro make a million dxfs
I've got a stack of DDT requests sitting on my desk that's about 3 inches thick and was hoping for some help writing a macro to do the heavy lifting. I already have a macro that will go through a directory of parts and open them sequentially. I also have a macro to save an entire directory of drawings to DXF. What I need help with is the middle part. I need to have the macro select the largest surface of the part, then insert that view into a new drawing based on a defined template. Can that be done? Does anyone have any code snippets that could help? Thanks in advance.
RE: Help with macro make a million dxfs
I'm not sure how you could find the largest surface to make a view. Depending on the orientation of the part = orientation of the view.
It could pick an internal surface and give you a weird view.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
It turned out to be quicker for us to generate each 3D model and drawing from scratch.
Once the first one is made, a template was created, then 'save as' new name. The parts were replaced using SW Explorer.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
Cheers,
Anna Wood
SW2014 SP2, Windows 7 x64
-handleman, CSWP (The new, easy test)
Handleman, PM me your info and I'll try to get you on the distribution list.
engineerville is my spot on the gmail service though.
Hopefully that's clear enough for a human to decipher, but too complicated for a bot...
