NX9 - some old drawings will not add new flat pattern view
Working here in NX9, coming from NX6. In NX6 we were using the old flat patterns...and naturally we are now moving to using the new ones. However, seemingly random, some of our old drawings do not list the new flat pattern layout when inserting the view. Yet if I start a new drawing a flat pattern view is selectable as usual. So perhaps this is a setting or disconnect with existing drawings (some of which may be quite old, stretching back to earlier versions of NX.
Any ideas what may be causing this and how to resolve it aside from creating a new drawing?
RE: NX9 - some old drawings will not add new flat pattern view
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
www.nxjournaling.com
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
It turns out that the drawing was selecting itself during the base view import, which naturally resulted in no flat pattern. However, in my case, the 'Select Part' window to choose the source wasn't appearing in my 'Base View' dialog box. Which means that I couldn't actually see the problem or solve it. The fix? I had to 'refresh' my dialog box using little circular arrow button next to the 'x'. After doing that the hidden 'select part' dialog was revealed with the drawing number highlighted instead of the required master model.
Hopefully this helps out others having the same issue. Although GTAC alerted us to the problem, we ended up figuring out the refresh part on our own after multiple users were not showing the same options in their dialog boxes.
