Solid Edge ST3 Converting asm. to .step then to .par as one part
Hi very new to the site.
I'm getting ready to have an .asm printed in 3D
So I've converted my .asm to a .step file and an .iges, then opened it as a .par, and finally into a .stl file for printing.... problem is when they go to print the part my weld gaps etc. will cause problems to print as one part. So in the .par file I want to fill in the weld gaps .. struggling.. (still learning on ST3).. Any thoughts would help.
RE: Solid Edge ST3 Converting asm. to .step then to .par as one part
Have your designer turn the assembly into a solid part, otherwise you will get a group of loose parts if this is a weldment.
Bill
Thank you BILLPSU. You are correct, when printed it will print as many parts as opposed to one unit. But that's the problem lol.. I am that guy and a bit new to ST3, I have brought the assy into .par and I have my weld gaps etc. question is how to join the pcs, tried a few things, just not seeing it or how to search this subject. any thoughts
Thank you KENAT, I've check this out, Still kinda looking, but did discover lots of other very useful information in the threads you directed me to..Thank you very muchbigsmile
