What is the difference happens on ASTM A453 660A and C on doing quenching
QC
RE: What is the difference happens on ASTM A453 660A and C on doing quenching
It really depends on if you have the Robertson-Henway or Franklin-Peters. With the Robertson-Henway, you have to use the rarefied oil, but you don't have to worry about cracking with the Franklin-Peters.
rp
You mean coz of the difference cooling rate strength will be different?
