Coordinates in a second axis system
hello!
I want to create a macro that gets the coordinates of a point (cercle origin), belonging in a part1, in the axis system of a second part (part2)!
TH U
RE: Coordinates in a second axis system
check the FAQ560-1377: XYZ of point to a text file about coordinates of a point.
You can use Position.GetComponents of the instances for Matrix multiplication in order to get the desired XYZ
with CATIA.ActiveDocument.Product.Products.Item(x).Position.GetComponents oAxisComponentsArray
Eric N.
