moisture conditioning nylon using sodium acetate solution
thread710-101768: Moisture Conditioning of Nylon
Pud - see referenced thread. Did you ever find that technical brochure? - I know, it's only been 9 1/2 years since that post. Just curious - I'd like to know more if you have access to it.
Thanks, Fofen
Thanks, Fofen
RE: moisture conditioning nylon using sodium acetate solution
Afraid I have still not come across it again. I'll have another rummage tomorrow.
It might be a problem for a chemist sorta person - I don't think it's much to do with nylon per se. Might be to do with solution strengths/mols/etc..
9 1/2 YEARS! Tempus fugit ok!
Harry
www.tynevalleyplastics.co.uk
It's ok to soar like an eagle, but weasels don't get sucked into jet engines.
