can ASME VIII design large, low pressure vertical storage tanks ?
Hello
can large, low pressure, vertical storage tanks be disgned according to ASME VIII ? if the answer is yes, which paragraphe is it ?
thank you in advance !!
RE: can ASME VIII design large, low pressure vertical storage tanks ?
It doesn't have provisions for flat bottoms supported on a foundation, and doesn't have provisions for structurally-supported roofs. It might also be overly conservative in the design of self-supporting cone or dome roofs.
Generally, if the pressure is less than 15 psi, then API-620 would be used, or if less than 2.5 psi, then API-650 would be used.
need more info on the tank.....depending on the pressure one can use some of design methods that are in the ASME but with lower FS.....
thank you JStephen and Sail3, that was the answer i was looikng for.
I apreciate your help
