Scan directory and give which part are inch
someone has a journal that scan a directory and give as result the file name where the part is in inch ?
Thank you...
Using NX 8 and TC9.1
RE: Scan directory and give which part are inch
It wouldn't take much effort to create something using the 'ug_inspect.exe' utility that you can find in the UGII folder of your NX install.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Cubalibre00,
Here is a "one-liner" that can be run from the "NX Tools, Command Prompt".
CODE --> NX_CMD_dos
for %i in (*.prt) do @("%UGII_BASE_DIR%\ugii\ug_inspect" "%i" | findstr /c:"Part units: Inches" > nul && echo %i)
Here is an NX Customize "System Command" that can be added to a tool bar.
CODE --> NX_Customize
start "inch parts" cmd  /k "for %i in (z:\*.prt) do @("%UGII_BASE_DIR%\ugii\ug_inspect" "%i" | findstr /c:"Part units: Inches" > nul && echo "%i")"
HTH, Joe
