Triangular load distribution on cylinder
Hi There. I am relatively new to Abaqus. I have a cylindrical tube (OD = 2 in. ID = 1.5 in.)and I am trying to apply a 10 kip load as pressure on once face of a cylinder following a triangular distributed load distribution. What I did is I tried to get my load equation, I looked at the cylinder from a 2D perspective and assumed my distribution to be as below:
| |<------ At x = 2 in., w = 0.5 x (10 kip x 2 in.) = 10 kip/in
| |<- At x = 0 in., w = 0 kip/in
In Abaqus, I created a rectangular CSYS with the x-axis along the direction of the diameter of the cylinder and defined an analytical field with a load function: w(x) = 10*(x/2) = 5*x
The cylinder has an OD = 2.0 in., ID = 1.5 in. Area = 1.37445 in^2
When I apply the load as pressure, do I put the magnitude as just P = 1/(Area) = 0.727565
I tried getting the reaction and it doesn't match the load I applied. I fixed the other end of the cylinder. Any help will be appreciated. Thanks!
