Catia V5 R20 Help?
Catia V5 R20 Help?
Catia V5 R20 Help?
Whenever I try to delete a geometry that has been used to create a pad, I get a warning message that can be seen in the attachment.
What should I do to be able to delete this sketch without this warning message?
I mean if you do it normally as I did and first create a sketch on the XY plane and then pad it and then on top of the first pad, start another sketch and then pad that one as well, now when you want to delete the second sketch you always get the specified warning message until you delete the second pad.
What is the solution to be able to delete the second sketch without deleting the pad?
I believe it is possible but I think I don’t know something in here and that is why I get this warning message.
Thank you.
RE: Catia V5 R20 Help?
In this second picture, you can see a file that I have and it works, but I don’t understand why it doesn’t work in files started by me.
So if you know please tell me.
I can't help you, but someone here might be able to ->forum560: CATIA products
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
