Appendix 2 Flange Calc
I have a slip on flange which is out of spec and need to check against Appendix 2 of Div 1 Code. The flange conforms to sketch (8a) of Fig 2-4 and I would like to design it as an optional integral type flange. In general note (b) of Fig 2-4 it refers to sketch (7) for loads and dimensions, however, sketch (7) has no hub. Am I to assume then that I can't take credit for the hub or is sketch (7) just typical?
Appreciate any help.
RE: Appendix 2 Flange Calc
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
prex
