Abaqus Error: Feature found, expecting tuple
Hi, I'm doing a Python Abaqus model and I need to use a reference point as a region in a BC. So, I have defined my reference point with this code:
refpoint1= proyectilPart.ReferencePoint (point= (0.0,0.0,0.0))
region = regionToolset.Region(referencePoints=refpoint1)
'ProyectilPart' is the part where i put my RF. I've got to create the RF, but I have a mistake in the second line because Abaqus send to me this error advertisement:"TypeError: referencePoints; found Feature, expecting tuple"
I don't know what I have to change, if someone can help me I'll thank him so much.
Thank you, and any help it will be well appreciated.
RE: Abaqus Error: Feature found, expecting tuple
Please try:
CODE
Bartosz
Please, if you or anybody has another idea, please answer me.
Thank you.
Do you mind to share the script so I can run on my side?
Bartosz
Right now, the code can be run and I have added "##" in the lines that I have the problems and a little note explaining it.
from abaqus import *
from abaqusConstants import *
import regionToolset
backwardCompatibility.setValues(includeDeprecated=True, reportDeprecated=False)
session.viewports['Viewport: 1'].setValues(displayedObject=None)
#Create model
mdb.models.changeKey(fromName='Model-1', toName='Impact')
shellModel = mdb.models['Impact']
#Create the shell
import sketch
import part
shellProfileSketch = shellModel.ConstrainedSketch(name='Shell CS Profile',sheetSize=5)
shellProfileSketch.rectangle(point1=(0,0), point2=(0.1,0.1))
shellPart=shellModel.Part(name='Placa',dimensionality=THREE_D, type=DEFORMABLE_BODY)
shellPart.BaseSolidExtrude(sketch=shellProfileSketch, depth=0.004)
#Create proyectil
import sketch
import part
proyectilProfileSketch = shellModel.ConstrainedSketch(name='proyectilProfileSketch',sheetSize=5.0)
proyectilProfileSketch.ConstructionLine(point1=(0.0,-100.0), point2=(0.0,100.0))
proyectilProfileSketch.Line(point1=(0,0), point2=(0.0065,0))
proyectilProfileSketch.Line(point1=(0.0065,0), point2=(0.0065,0.025))
proyectilProfileSketch.Line(point1=(0.0065,0.025), point2=(0,0.025))
proyectilPart= shellModel.Part(name='Proyectil', dimensionality=THREE_D, type=ANALYTIC_RIGID_SURFACE)
proyectilPart.AnalyticRigidSurfRevolve(sketch=proyectilProfileSketch)
#Create Reference point
##HERE IS THE PROBLEMATIC LINE, I DON'T KNOW WHAT I HAVE TO CHANGE
##region = regionToolset.Region(referencePoints=(refpoint1,))
#Create shell material material
import material
import odbMaterial
shellMaterial=shellModel.Material(name='Aluminio')
shellMaterial.Density(table=((7850, ), ))
shellMaterial.Elastic(table=((2e+11,0.33), ))
shellMaterial.InelasticHeatFraction(fraction=0.9)
shellMaterial.Plastic(hardening=JOHNSON_COOK, table=((231.7E+06, 1147.7E+06, 0.546, 0.94, 1800, 293), ), rate=ON)
shellMaterial.plastic.RateDependent(table=((0.046694, 0.002), ), type=JOHNSON_COOK)
shellMaterial.SpecificHeat(table=((452, ), ))
#Create the section
import section
shellSection = shellModel.HomogeneousSolidSection(name='Shell Section', material='Aluminio')
shell_region = (shellPart.cells,)
shellPart.SectionAssignment(region=shell_region, sectionName='Shell Section')
#Create assembly
import assembly
shellAssembly = shellModel.rootAssembly
shellInstance = shellAssembly.Instance(name='Shell Instance', part=shellPart, dependent=ON)
proyectilInstance = shellAssembly.Instance(name='Proyectil Instance', part=proyectilPart, dependent=ON)
shellAssembly. rotate(instanceList=('Proyectil Instance',), axisPoint= (0,0,0), axisDirection= (0.001,0,0), angle=(90))
shellAssembly. translate(instanceList=('Proyectil Instance',), vector=(0.05,0.05,0.0045))
#Identify surfaces for the interactions
shell_top_surface_point = (0.05,0.05,0.004)
shell_top_surface = shellInstance.faces.findAt((shell_top_surface_point, ))
proyectil_botton_surface_point = (0.05,0.05,0.0045)
proyectil_botton_surface = proyectilInstance.faces.findAt((proyectil_botton_surface_point, ))
proyectil_top_surface_point = (0.05,0.05,0.0295)
proyectil_top_surface = proyectilInstance.faces.findAt((proyectil_top_surface_point, ))
proyectil_side_surface_point = (0.0565,0.05,0.01)
proyectil_side_surface = proyectilInstance.faces.findAt((proyectil_side_surface_point, ))
#Create the step
import step
shellModel.ExplicitDynamicsStep(name='Impact', previous='Initial', timePeriod=0.001)
#Create interaction
frictionless_interaction= shellModel.ContactProperty('Frictionless')
frictionless_interaction.TangentialBehavior(formulation=PENALTY, fraction=0.005, table=((0.1, ), ))
frictionless_interaction.NormalBehavior(pressureOverclosure=HARD)
set_seq = proyectil_botton_surface
set_seq += proyectil_top_surface
set_seq += proyectil_side_surface
shellRegion = regionToolset.Region(side1Faces=shell_top_surface)
proyectilRegion= regionToolset.Region(side1Faces=set_seq)
shellModel.SurfaceToSurfaceContactExp(name='Interaction', createStepName='Impact', master=shellRegion, slave=proyectilRegion, sliding=FINITE, interactionProperty='Frictionless', mechanicalConstraint=PENALTY, weightingFactorType=SPECIFIED, weightingFactor=1)
#Create the field output request
shellModel.fieldOutputRequests.changeKey(fromName='F-Output-1', toName='Selected Field Outputs')
shellModel.FieldOutputRequest(name='Selected Field Outputs', createStepName='Impact', numIntervals=60)
shellModel.fieldOutputRequests['Selected Field Outputs'].setValues(variables=('PE', 'PEEQ', 'S', 'STATUS', 'TRIAX', 'U', 'V'))
#Create the history output request
#shellModel.HistoryOutputRequest(name='Default History Outputs', createStepName='Impact', variables=PRESELECT)
#Create the boundary condition
#Create encaster
fixed_end_face_pt_x= 0
fixed_end_face_pt_y= 0.05
fixed_end_face_pt_z= 0.002
fixed_end_face_pt = (fixed_end_face_pt_x, fixed_end_face_pt_y, fixed_end_face_pt_z)
fixed_end_face = shellInstance.faces.findAt((fixed_end_face_pt, ))
fixed_end_face_region=regionToolset.Region(faces=fixed_end_face)
shellModel.EncastreBC(name='Encaster one', createStepName='Impact', region=fixed_end_face_region)
fixed_end_face_pt_x= 0.05
shellModel.EncastreBC(name='Encaster two', createStepName='Impact', region=fixed_end_face_region)
fixed_end_face_pt_y= 0.1
shellModel.EncastreBC(name='Encaster three', createStepName='Impact', region=fixed_end_face_region)
fixed_end_face_pt_x= 0.1
shellModel.EncastreBC(name='Encaster four', createStepName='Impact', region=fixed_end_face_region)
#Proyectil displacement
fixed_end_face_pt_z= 0.004
##HERE IT IS THE LINE WHERE I HAVE TO USE THE RP AS A REGION
##shellModel.DisplacementBC(name='Proyectile displacement', createStepName='Impact', region=region, u1=0, u3=0, ur1=0, ur2=0, ur3=0)
#Predefined Field, Temperature
#shellModel.Temperature(name='Temperature', createStepName='Impact', region=fixed_end_face_region, distributionType=UNIFORM, crossSectionDistribution=CONSTANT_THROUGH_THICKNESS)
#Create the mesh
import mesh
shell_inside_xcoord=0
shell_inside_ycoord=0
shell_inside_zcoord=0
elemType1 =mesh.ElemType(elemCode=C3D8R, elemLibrary=STANDARD, kinematicSplit=AVERAGE_STRAIN, secondOrderAccuracy=OFF, hourglassControl=DEFAULT, distortionControl=DEFAULT)
shellCells=shellPart.cells
selectedShellCells=shellCells.findAt((shell_inside_xcoord, shell_inside_ycoord, shell_inside_zcoord),)
shellMeshRegion=(selectedShellCells,)
shellPart.setElementType(regions=shellMeshRegion, elemTypes=(elemType1,))
shellPart.seedPart(size=0.001, deviationFactor=0.01)
shellPart.generateMesh()
#Create and run the job
import job
mdb.Job(name='ShellImpactJob', model='Impact', type=ANALYSIS, explicitPrecision=SINGLE, nodalOutputPrecision=SINGLE, description='Job simulates a proyectile impact', parallelizationMethodExplicit=DOMAIN, multiprocessingMode=DEFAULT, numDomains=1, userSubroutine='', numCpus=1, memory=50, memoryUnits=PERCENTAGE, scratch='', echoPrint=OFF, modelPrint=OFF, contactPrint=OFF, historyPrint=OFF)
mdb.jobs['ShellImpactJob'].submit(consistencyChecking=OFF)
mdb.jobs['ShellImpactJob'].waitForCompletion()
