Print Results and Export Results are not same(NX7.5.3)?
Generally Drafting outputs are same either we print out to pdf or we export to pdf. But the problem I am facing is that there is lot of difference between the two of them either because of system settings or because of printer settings.
Images showing differences are attached as well.
Is there any way to match those outputs? I have checked with Resolutions and line widths but results didn`t changed at all.
I have tested Export TIFF as well. The results of Export TIFF were same like the print pdf. But the CGM created was always good.
Ishant
Ishant
RE: Print Results and Export Results are not same(NX7.5.3)?
plotting on the other hand is a vector export and therefore scalable.
Tiff, PNG etc are screendumps / Raster data.
The Pdf export is vector data. ( It is probably based on a internal CGM export.) CGM again is Vector.
Tomas
