organizing sheets in CATDrawing
I am making multiple sheet drawing. The order has changed and I need to put sheet 6 where sheet 2 would be. I know you can re-label the sheets but i need them to be in order in the CATDrawing as well. I have read solutions on here to cut and paste but when I try that it tells me paste is not allowed. I am working in V5-6R2013.
RE: organizing sheets in CATDrawing
try Copy Paste Delte versus Cut and Paste.
Please select the sheet ...right click reorder....select the destination of the existing drawing....its very simple....
sudharkan, yes I figured this out after I sent out the question. This is the way to do it thanks. Cut and paste does not work, not sure how others are doing it this way.
