stresses in a steel band clamp
I have a design that requires a steel band to be clamped around a round steel shell. For reference the band is 1/2" thick x 4" wide and clamps around a steel cylinder 36" diameter and 1/4" wall. Given that I know the tension on the band clamp how does this force determine the radial stress the band is placing on the steel shell?
RE: stresses in a steel band clamp
