Composite Deck from 1990
I am checking the capacity of an existing floor deck the reads on the plans, "4-1/2" CONCRETE SLAB ON 2" DEEP 20 GA. GALV. COMP. META FLOOR DECK REINF. WITH 6X6-W1.4XW1.4 WWF."
Should I assume this deck has the same capacity as modern 2VLI deck?
RE: Composite Deck from 1990
Do you even know the gage of the deck, and whether or not it was shored during construction?
Mike McCann
MMC Engineering
