Save images Abaqus Viewer
Hello everyone!
Here is what I would like to do : Choose a view (and if possible margins) and save automatically the same image at each step time. Do you know if something like this is possible? Is there a manner to do it with Abaqus? Otherwise, is there a way to do it with a matlab script or so?
Another question about the step time : I'm using measured data which go from 0 to 700-800 seconds. I create a step of 600 seconds. The step will take only the 600 first data or will it do something like an interpolation to "compress" the 800 seconds into 600?
Thanks a lot for your help!
RE: Save images Abaqus Viewer
1) write an animation to an avi file. then convert to single pictures usings a freeware
2) will use only the first 600 seconds
Thanks a lot for your answer. I will try this.
