problem with reference
Bonjour!! ponytails2
I have a problem with reference of selection!!
CODE -->
MsgBox "select a hole"
Dim InputObjectType(0), Status1
InputObjectType(0)="Hole"
Status1=selection1.SelectElement2(InputObjectType,"Select a hole",false)
If Status1 = "Cancel" Then selection1.Clear: Exit Sub
Dim reference1 As Reference
Set oHole = selection1.Item(1).value
Set reference1 = selection1.Item(1).Reference
Set reference1 = selection1.Item(1).Value.Reference
the red one are wrongs!!
how can I get the reference
th u soapbox
RE: problem with reference
solution is in online doc (with many other good stuff worthy to read)
sorry but ...RTFM
Installe la doc et prend 15 minutes a regarder ce qu il y a dedans a propos de reference... Il y a des methodes pour creer des references
Eric N.
je l'ai utilisé avec la selection des point et c a bien marché!!!!
mais dans ce cas c'est bizarre!
sorry et ... METC
check this
Eric N.
hahahaha!!
Quote (fedro)
METC
Merci En Tout Cas! thank you anyway
