Hydraulic cement
Hydraulic cement
Is it appropriate to use hydraulic cement to fill a pipe sleeve, in the basement wall, that is not needed? On the outside (the soil side), the sleeve is covered over by the same waterproofing material applied over the basement wall.
Or, if it's more appropriate to use non-shrink grout?
I appreciate any thoughts on this one.
RE: Hydraulic cement
Frankly if it isn't structural and isn't architectural (waterproofing and appearance) fill it with anything that will stay.
