API 12F Tanks
API 12F Tanks
API 12F Tanks
Does OSHA or NFPA limits the use of API 12F tanks in flammable service?
I wonder if this type of tank can be used to store flammables of NFPA rating:2,3,4; for example: toluene, methanol, etc.
RE: API 12F Tanks
No, the storage and handling of flammable liquids is regulated by specific standards as follows:
OSHA standard 29 CFR 1910.106 – Flammable and Combustible Liquids
NFPA 30
UL 142
Refer also to the list of reference documents included with above standards.
Cheers,
gr2vessels
RE: API 12F Tanks
12F tanks work pretty well in those services. Look at using an inerting blanket, and put an Emergency Relief device in the roof hatch [manway]. I like ProtectoSeal 53300 [but everybodies work well].
