Tighten nut on clamp T-bolt "snug": What the heck is "snug".
4
We use the term "sung" for installing parts "tight-but-not-too-tight". Most of us have a "feel" for what snug is.
HOWEVER, recently, several of us got together to define "tighten-snug" for a 0.250-28 plain nut. None of us had a clear definition for the mechanic who wants to now what "snug-torque" is... or what a snug fit of parts is.
How do You define the term "snug" as related to torque and mating-part fit???
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
Unfortunately, in science what You 'believe' is irrelevant – "Orion"
RE: Tighten nut on clamp T-bolt "snug": What the heck is "snug".
This has been discussed in the Structural forums, where 'snug-tight' means, if I recall correctly, a 250# ironworker hanging on the end of a spud wrench. I don't find that definition appealing, but in the structural steel world, that's what it is.
For me, with a little experience in AGE and automobiles, it means 'press your thumb on the end of the wrench', which equates to about 20# x the wrench length. My Dad said something that calculated out to 'a little less than yield', after threatening to cut all my wrenches in half. Later, I developed a 'feel' that would put it at a little less than that, i.e. just as the joint 'tightens up'. Now, I'd put it as about half of the yield torque, with Never-Seez on the threads, and maybe just a film on the nut face.
Mike Halloran
Pembroke Pines, FL, USA
remember that picture "who decides how much to tighten a bolt ?" ... the analyst or the mechanic ...
Quando Omni Flunkus Moritati
According to Guide to Design Criteria for Bolted and Riveted Joints by Kulak, Fisher and Struik:
Quote:
The snug condition was defined as the point at which the wrench started to impact. This occurred when the turning of the nut was resisted by friction between the face of the nut and the surface of the steel. Snug-tightening the bolts induces small clamping forces in the bolts. In general, at the snug-tight condition the bolt clamping forces can vary considerably because elongations are still within the elastic range.
For bolts equal to or greater than about ¾ in. dia., snug position provided by an impact wrench is approximately equal to the tightness attained by the full effort of a man using an ordinary spud wrench. For longer or larger diameter bolts, the force produced by this snug load will be less than that for the “standard” case, and for shorter or smaller diameter bolts it will be more. These differences are accommodated in the specification by prescribing the same definition of snug tight for all cases but varying the degree of rotation required beyond snug for different situations.
According to Specification for Structural Joints Using High-Strength Bolts by the Research Council on Structural Connections:
Quote:
Snug-Tightened Joint. A joint in which the bolts have been installed in accordance with Section 8.1. Snug tight is the condition that exists when all of the plies in a connection have been pulled into firm contact by the bolts in the joint and all of the bolts in the joint have been tightened sufficiently to prevent the removal of the nuts without the use of a wrench.
8.1 Commentary: The snug tightened condition is typically achieved with a few impacts of an impact wrench, application of an electric torque wrench until the wrench begins to slow or the full effort of a worker on an ordinary spud wrench. More than one cycle through the bolt pattern may be required to achieve the snug-tightened joint.
Oh, wait.
There is a spec for t-bolt nuts: 50 in-lb., no more.
Mike Halloran
In the aerospace world, I have never seen plain nuts used to secure the T-bolts on band clamps. The typical procedure for installing the clamp would be to first measure the running torque of the lock nut to verify that its locking feature is still within spec. And then the lock nut is torqued to a value above the measured running torque.
I would never use subjective terms like "snug" when describing a critical assembly process. Such written process descriptions should always be specific, and should never leave anything open to interpretation.
Allow me to clarify my experience with 1/4-28 T-Bolt clamps.
In the marine exhaust industry, we use two types; V-band and flat (hose) clamps, all sourced from Voss or similar outfits, all with stainless bolts and all-metal self-locking nuts (the kind that look castellated), usually with some kind of anti-gall coating on the nuts.
If you don't put Never-Seez on the bolts, they'll gall before you ever get them tight. With the Never-Seez, by the time you get them run down to start tightening the joint, most of the prevailing torque is gone anyway.
The clamps with flat bands are used on silicone hose; going tighter than 50 in-lb cuts the hose, which is hideously expensive, and doesn't make the hose seal better.
The clamps with V-bands are used to secure beveled flange pairs, which are sealed with water glass, and manually brought into secure contact before the clamps are tightened. Using the clamps to move the (stiff) pipes just distorts the clamps and guarantees that the joint will leak. 50 in-lb is enough to securely tighten the clamp on a properly made up joint, and more torque doesn't help an improperly made up joint.
Your mileage may vary.
Don't believe me; call Voss (216) 771-7655.
Also see vossind.com
Mike Halloran
Snug is way short of fully tensioned, in my workshop. It'd be hard enough to grip, but not necessarily developing much tension. So for example, you'd snug the cylinder head bolts up before doing the tightening pattern.
Indefinable, therefore unacceptable, yet obvious.
You guys seem to be going for more torque than that.
Cheers
Greg Locock
All..
In this particular situation I have a very unusual band-clamp installation. See attached "scrubbed drawing".
The T-Bolt [A286 130-KSI HT] is secured with an MS9360-10 [0.250-28 UNJF-3A] plain hex nut, A286 silver plated. The Bleed Air Duct [Inconel-625, 3"OD X 0.035-WT] can experience -65F to +820F + 45-PSI thermal/pressure loads/strain
Per the drawing NOTE, the T-Bolt nut is to be installed as follows...
TORQUE REQMT: DO NOT TORQUE TRUNNION NUT. TIGHTEN NUT FOR SNUG FIT. Note: after "tightening to a snug-fit", the nut is then lock-wired to the clamp loop [holes drilled-thru the hex-corners].
Unfortunately these instructions were "lost in translation", when the MM was written: we now are experiencing crushed ducts due to application of "nominal" torque for a 1/4-28 nut [65--85-in#].
Here is what I wrote to define "snug"; however it was not considered acceptable to the MM owner because they are committed to have torque values listed and cannot allow not amorphous torque procedures like this [military] in their MM.
b. Install xxxxxxx duct support clamps (6) on bracket
(1) with bolts (7), washer (8), and nuts (9). Torque
mounting nuts (9) 65 to 85 inch-pounds. Install T-Bolt
Nut (6a) on threads and run it down until it is “snug
and lockwire the nut to adjacent clamp loop per NASM33540.
SNUG Nut (6a) as follows.
Use a screw-driver with a deep-socket bit or a short
handle box wrench to tighten Nut (6a) "snug" as follows.
Run the nut down on the T-bolt threads. As soon as You
feel the plain Nut transition from smooth run-on torque
to a noticeable torque-rise, then stop: the nut is
SNUG! Inspect each clamp installation to ensure the
duct wall under the clamp is round and smooth (does NOT
have a “pinched/wrinkled/wavy” appearance). IF Duct wall
is distorted, then loosen Nut and gently "re-snug" it.
Here is how they ended-up word-smithing para c [approximately]...
mounting nuts (9) 65 to 85 inch-pounds. Torque T-Bolt
Nut (6a) 5--15 inch-pounds and lockwire the nut to
adjacent clamp loop per NASM33540. Inspect each clamp
installation to ensure the duct wall under the clamp is
round and smooth. IF Duct wall is distorted, then loosen
Nut (6a) and gently re-torque to low end of range.
Comments?
Regards, Wil Taylor
Trust - But Verify!
I should note that hot FRP becomes plastic, so we made 'crush sleeves' to be bonded inside FRP muffler nipples, to resist the stress applied by the hose clamps.
If the duct you're trying to retain is made of, er, foil, maybe it needs internal reinforcement at the clamp plane.
The redacted drawing suggests that maybe you're using the clamps to press a round thin duct against, e.g. a rib or stringer or other not strongly curved object. If the tube's entire OD is not supported either internally or externally, then it's liable to crushing at even moderate clamp loads.
Even if there is some kind of saddle not shown, the stress situation on the OD of the tube is not uniform. You draw the clamp leaves nicely curved, but when you apply tension, they try real hard to straighten out, again leaving the tube liable to distortion. You could specify a full circle clamp, and equip it with an ear to be attached to the structure. Talk to Voss about options; this is not their first rodeo.
Mike Halloran
wktaylor,
I do not think your concept of "snug" is meaningful. I have been trying to work out how to install screws finger tight, and rotate them some specified angle, to my required clamping force. For most smaller screws, the transition from finger tight to the yield stress of the screw is only a few degrees. I rarely use screws over 3/8" or 10mm diameter.
For this to work, I need an extremely precise concept of "finger tight". I think your concept of "snug" is even more adventurous. Can't you estimate the force you want, and work out the screw torque? For my calculations, I assume an infinitely rigid joint. In your case, the joint is flexible, and screw turns from finger tight might work.
JHG
I would suggest a slight variation on what drawoh said
One could approach it form a strain point of view, something along the lines of "tighten till the clamp is no longer loose to the touch, then apply 1 to 2 more turns of the nut".
Given that you're using lockwire on plain drilled nuts, a torque spec may be a perfectly reasonable and repeatable way to go, but ordinary torque wrenches are not the correct tools for 'snug' torque ranges.
Get a 'torque watch' in a couple of ranges, fitted with a 1/4" square drive adapter, and use them to establish a range that is acceptable to you.
Bring your wallet...
Mike Halloran
Quote (verymadmac)
According to my spreadsheet, an M5X0.8 A2-70 stainless steel screw clamping through 35mm, reaches its yield point at about a 37° turn. I am assuming that the joint is very much more rigid than the screw.
Question: If you, MikeHalloran, GregLocock, wktaylor and I each install a screw finger tight, what will the variation be in degrees?
My strategy for accurate torquing of screws within yield strength is hopeless. If I had longer, higher strength screws, clamping something with significant and known flexibility, my system could work.
If I trust everybody to systematically use each screw once only, a full turn of the screw keeps things well below the ultimate stress of an austenitic stainless steel screw. This does not solve the OP's problem.
JHG
From Wil's last post, I infer that the bleed air duct is very thin and easily distorted, which suggests that the torque increase per degree will be rather gentle, which in turn suggests that 'turn of nut' might be viable, provided once again that 'snug' can be defined in some reproducible way.
So, let's back up a little.
'NOT snug' could be defined as 'loose enough so the parts can be wiggled a little'. So for purposes of this discussion, 'snug' could be locally defined as "just tight enough to the parts don't wiggle". ... and the design team, privy to the redacted details about the duct, could take it from there.
I personally would try to redesign the assembly so that a one-piece clamp just tightens around the duct, and then the clamp is secured to the aircraft by means of ears built into the clamp. I.e., I think the trunnion style clamp and the implied saddle that I hope is there and their nonidealities conspire to make it too easy to deform the duct while attempting to secure the clamp to the duct. Or just weld ears to the duct, making them long enough and flexible enough to limit heat transfer and duct distortion to the airframe.
Mike Halloran
There's a huge issue with grease/dirt on the threads if you are attempting to define a torque. As an example we had one design where a 30mm approx nut had to be torqued to approximately 1.4 Nm (about what you could apply by hand between thumb and finger) which was easy to do as a one off, because you could feel if there was any problem. But, we needed one every 30 seconds so we had a machine. It was hopeless.
Cheers
Greg Locock
wktaylor-
Thanks for the detailed description of your problem. Makes it much easier to suggest a possible solution.
I think MikeHalloran's suggestion for tightening the nut using an angle value rather than a torque value is the way to go. You can place a .009" thick feeler gauge between the mating faces of the nut and clamp lug, and then finger tighten the nut until you feel some sliding resistance on the feeler gauge. This .009" axial clearance is equal to 1/4 turn of the .250-28 nut. So all that is left is to tighten the nut another 1/4 turn for contact, plus some small additional amount (maybe another 1/8 turn) to ensure the nut is firmly seated.
This should produce the "snug" condition you desire, it only requires a wrench and a feeler gauge, it is a fairly simple procedure for the mechanic to follow, and it eliminates variables like thread frictions.
Hope that helps.
Terry
I would think with the aerospace or aeroplane industry that snug would be defined in the specifications for a fastener. With construction and structural steel, there are so many fasteners and a relatively 'crude' environment for installation, that a rough identification of tightening has to be understood... Snug is considered to be the maximum effort on a 'spud' wrench... a standard tightening wrench that increases in length depending on the fastener size. This is a similar effort as when an impact wrench first starts to impact. It is a rough measure of tension that will prevent a nut from loosening by itself. It is out of place with the aerospace industry...
Dik
dik-
The modern aerospace industry requires specific, well-defined procedures for everything it does, including design, manufacturing, procurement, testing, assembly, maintenance, etc. Thus, subjective terms like "snug" are normally not acceptable in written requirements or procedures. Requirements and procedures are always written so that there is nothing left open to interpretation, and also that there are clearly defined methods of validating the procedure was performed correctly.
The modern auto industry takes a slightly different tack, because it can't enforce the procedures it publishes, but still has most global governments and all the trial lawyers in the world peeking over its shoulder.
Its response comprises things like fluid couplings that snap together with an audible click, with primary retention provided by a garter spring and sealing provided separately by an o-ring, and with secondary retention provided by a spring clip, all assembled without tools or torque specs. They're also lightweight enough to deserve investigation by the aero crowd. I'm not sure that aero alloys would do well with the extreme forming required to make the ends, but it seems worth a look.
Have you looked at an auto OEM radiator hose recently? No more worm-drive clamps, no expensive t-bolt clamps, but more likely a spring clamp that requires a tool to open, and springs into place when released, with applied forces controlled by design and dimension, not procedure. I think I've even seen shrink-tube in that application.
I know that redesign or replacement of the t-bolt clamp is not within the purview of the original question, but maybe it deserves a sticky note somewhere.
Mike Halloran
All… some more info...
See attached photo of damaged duct section. The effect of clamp T-bolt over-torquing is pretty obvious.
The evident pinching/flattening and rectangular [sharp-cornered] creases are enough to cripple/fail the duct per a theoretical analysis and testing program accomplished for critical hot-air/high-pressure pneumatic ducting of another acft, that is critically reliant on this system. I think the only saving grace, RE our duct damage, is that the clamps, in addition to damaging the duct, also provide some strain restraint to keep the distorted wall from continuously flexing [fatiguing]; and that the system is statically pressurized without significant airflow during most of the flight.
NOTE.
This same ducting section, and adjacent ones are, are experiencing significant flexible bellows damage. This raises a larger issue in my mind, IE: how these duct sections are connected to other duct sections and mounted to the engine/airframe. My prior experience with pneumatic ducting with strain-relief bellows, like this, is “how they are assembled together makes a huge difference in assembly and localized/operational strain”. I found that loosely clamping duct sections together, then loosely installing structural clamps/mounts, then slowly/methodically tightening the duct sections together and to-the-mounts-to-the-structure, usually brings the entire assembly into a minimal strain “best fit” situation. However, this some-what long-drawn-out procedure requires the maintenance tech to mix-in “maintenance art” with the raw-procedures listed in the MM… and NOT rush the job. Unfortunately this might not be the case here… along with the improper clamp-torquing procedures.
Regards, Wil Taylor
Trust - But Verify!
Yeah, the slow, gradual tightening is how it's done on yacht exhausts, too. Further, the tubes are typically suspended by rubber washers and helical compression springs, and not rigidly tied to the boat anywhere, both for reduction of conducted noise, and to minimize the installed stress in the tubing.
That bleed air duct appears to be made of foil, or something close.
... Which suggests that those clamps are _way_ too strong, and way too stiff, and assume the wrong shape when overtightened. If workmanship and uniformity could be assured, you'd be better off securing the duct with lockwire alone.
Have you looked in a Tinnerman catalog?
Mike Halloran
Follow-up NOTES.
Duct tubing is 0.035-inch WT X 3.0-inch OD Inconel 625 annealed.
The duct analysis, I mentioned above, was actually run for similar OD ducts... but ~1/2 that wall thickness [0.016--0.020-inch WT] made from a different heat resistant alloy [HRA]. The study suggested that creased dent stress concentration was far worse as the duct wall was thickened [stiffened]: the thinner wall tends to allow duct to attain a "rounder-shape" with lower strain; whereas the thicker wall duct retains its distorted shape due to much higher stiffness. In-all-cases, sharp corner dents [shown] have the highest KT relative to "pure" length-wise or circumfrential dents alone.
Regards, Wil Taylor
Trust - But Verify!
You could put springs under the T-bolt nuts and tighten to a set spring compression.
Actually, with the proper springs, you could set up the 't-bolt' with no threads to adjust, and a quick-release overcenter latch. ... thereby controlling the installation with design and manufacturing tolerances, not assembly procedures.
ISTR a detail like that in a Voss catalog.
Mike Halloran
wktaylor-
Thanks for the photo and the additional information.
One thing that caught my eye in the photo was that it appears the lower clamp location is located on a bend, but it may just be an optical illusion. It's a bit unusual to clamp in the middle of a tube bend, since all-metal clamps (like your example) are not really designed to accommodate the lengthwise curvature in the tube wall.
Since your clamp installation procedure must be based on using the existing components, as I noted above I think the best approach would be to tighten the t-bolt using a dimensional value. Looking at the sketch of the clamp installation you provided, it would seem easy enough to first take a measurement between the inside surfaces of the strap loops (the .52" reference dimension in the sketch) with the strap loops squeezed together using finger pressure. Then the t-bolt would be tightened to an easily controlled/measured lesser distance between the strap loops.
It is easy to see how tightening the t-bolt using a torque value could result in the damage to the tube that you show. Once the tube wall yields due to forces from the clamp, the wrenching torque required to tighten the t-bolt further should not increase much. The mechanic would have no way of knowing that the tube wall has yielded, and would simply continue to tighten the nut, probably wondering why the wrenching torque never reaches the spec value even after applying way more turns on the nut than should be necessary.
Lastly, you mentioned there were some stress failure issues with the metal bellows between duct sections. I spent some time working for a company that specialized in designing/manufacturing aircraft duct systems. One thing I learned during that time was just how complex designing a high-performance metal bellows actually is. They are designed for very specific operating conditions, including angular, radial and axial displacements. It is easy to imagine how excessive misalignment at installation of the ducts could produce overstress in the bellows.
Terry
I'm surprised at the design of the joint, given the range of temperatures. There is considerable thermally induced size change in the tube that isn't going to be followed by the bolt fast enough. It seems too stiff tangentially. Sometimes grabbing an item too tightly is worse than letting it rattle.
It doesn't seem that the design is as well investigated as it should have been. A better look at the thermal effects, especially transient conditions, would be worthwhile.
3DDave-
The effects of uneven thermal expansion is a serious concern with this kind of high temp bleed air ducting. It is critical not to over-constrain the ducting with the clamping. With a bleed air duct operating at up to 800degF attached to a nacelle structure that might be 700degF cooler, it is important to ensure the duct attachments allow for adequate thermal expansion without over-stressing the duct components.
The subject half-clamp doesn't get anywhere close to meeting that spec.
</dead horse beat-down>
Mike Halloran
Yeah, I know: the clamp design/installation in my humble opinion s*cks. There is a matching saddle mount contoured to the the tube OD radius... but it only spans about 90-deg [+/-45 from center of contact]. There is no "flexibility" to this design for thermal and pressure effects; perfect clamp fit, not-too-tight/not-too-loose, is all-important... unlike flexible installations suggested by Halloran, 3DDave and tbuelna.
This design is way-down the road, and no redesign feasible [customer is not able without heroic effort... and other problems are far worse than this (another story)].
Thanks for great imput!
NOTE. I do like tbuelna's suggestion RE tightening the clamp T-bolt nut, until a thin feeler gage begins to bind-up between the tube OD and the clamp ID.
NOTE. SAE AIR809 Metal Dimensional Change with Temperature is helpful for calculating thermal expansion from RT to +/-xxxF!
Regards, Wil Taylor
Trust - But Verify!
1/8" of silicone sponge rubber between the clamp and the duct would do wonders.
Yep, it should burn real nice.
Mike Halloran
