Interpreting control characters in string
Greetings all!
Is it possible while displaying contents of a string expression to interpret control characters included in that string?
Example: string expression with a value of "<U>0<U>" will be shown as <U>0<U>. Is it possible to display it as a underlined zero?
RE: Interpreting control characters in string
What version of NX, and to where are you going to display this string?
www.nxjournaling.com
Version 8.5 and above.
Not sure I understand "to where". I'm going to show it on the drawing.
NX should interpret the string '<U>o<U>' as an underlined O when placed on a drawing.
Ben Loosli
If I write this directly - in interprets it like that.
If I try to display a string expression then it does not.
The best that you can do is create the expression with a string value of "O" and then when you place it on your Drawing using the Text editor format your 'statement' as...
<U><X0.2@text><U>
...where text is the name of the expression with the value of "O".
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John,
I used this only as an example. I'm trying to figure out the possibility to interpret control characters in strings. The strings themselves could be changed according to the values of some other expressions, and control charcters therefore could come and go. For example:
Case 1. ATTR string has value of 1. Displays 1
Case 2. ATTR string has value of 1 <U>0<U>. Displays 1 0
Perhaps it's too much to ask?
OK, this is a bit of a 'kludge' but it will give you what you want.
Open the attached Drawing file and go to the Expression dialog and change the value of underline from true to false (this is not a string expression so no double-quotes are needed) and hit OK and your note will change from 1 O to 1 O.
This was accomplished by creating TWO notes superimposed over each other, one with the 'underline' as I suggested in my previous post and the other without. I then went into...
Edit -> Suppress Drafting Object...
...and assigned one of the notes to one of the mod_X expressions and the other to the other. Now the 0 and 1 values of these two mod_X expressions are controlled by the value of the underline expression.
Now you can change the content of the 'note' by simply editing the num and text expressions.
Anyway, take a look and see if this will work for you.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John!
Thanks for the hint! Yes, it works.
Another solution:
Create a part attribute (type string) that refers to your string expression. Add a note to your drawing referencing the new part attribute. It will fill in the note text something like:
<WRef1*0@theexpname>
Edit the text to add an ampersand character (&) after the W, so it looks like:
<W&Ref1*0@theexpname>
The text control characters will now be interpreted correctly.
Oops, theexpname above should be theAttributeName instead...
John,
Would be wonderfull if this "Suppress drafting object" could also supress a view.
BTW, where, after creating this "rule", can we delete it ?
Thank you
"My english is bad ? That's why i'am french."
What 'rule' are you talking about?
As for the suppress a view option, yes that would be useful. Please contact GTAC and have them open an ER (Enhancement Request) to that effect and it will be given consideration.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
