Need to know how to create a drawing format with a permanent table for every to use in each drawing.
I want to have one drawing format that will have a specific name that will always be used as a quality plan as the last sheet in our drawings. I need to know how I can add a table to this format save it off into the database so anyone can add this sheet to a drawing and be able to edit the cells.
I have loaded a format with a specifice name and added the table and then did "Save Sheet Format" and when I created a new drawing and added a sheet using this special format it loaded but the table was missing.
RE: Need to know how to create a drawing format with a permanent table for every to use in each drawing.
Chris, CSWA
SolidWorks 13
ctopher's home
SolidWorks Legion
Tables are not added to the Sheet Format, only the sheet.
