Grouping AutoCAD icons in taskbar Windows 7
I would like to have only the one button per running AutoCAD application in my taskbar so that ALT+TAB cycles to the other program (like Excel) rather than the previous drawing (what the hey?!).
I've read some posts about setting the "taskbar" value to "0", but no one says where I can set this value. If I type "taskbar" in the command prompt I get this reply from the mighty prompt:
"'taskbar' is not recognized as an internal or external command,
operable program or batch file."
Same with "taskbar 0", "taskbar=0", "taskbar = 0". etc.etc.
Your help is greatly appreciated!
Griffin
Griffin
RE: Grouping AutoCAD icons in taskbar Windows 7
Griffin
