How to choose thed right API 650 edition
i am designing a storage tank according to API 650 standard, i have access to 2007 , 2009 and 2013 edition of API650.
Questin: which one shoold i choose? and for futur reference, how do i usually make my choice?
thank you .
thank you .
RE: How to choose thed right API 650 edition
As you will need some sort of sign off / QA check / approval, if you haven't used the latest code, you might not get that sign off.
The only way you can use old codes is when the client demands it or you do repairs or changes to an existing tank designed to that particular code.
If API 650 has not been adopted as code, you may need to educate the local agency about it. Years ago I did quite a bit of civil work for a petroleum tank farm in central California. One day, my southern California-based client asked me to handle the permitting grunt work for a steel tank they wanted to add to the site, basically become their interface with the City of #$%^&, which had recently annexed the site. The tank design was done by a southern California structural engineer per API 650. Several weeks after I turned in the plans, calcs, geotech report, etc, I received a call from the structural engineer at the city who had reviewed the project. He told me that there were serious problems with the design and that it didn't meet the building code in a number of areas. I set up a meeting with him for the next week, then called my client and asked him to rush me a copy of API 650 (this was pre-World Wide Web and, although I had had a lot of experience with AWWA D-100, I had never seen API 650). My client rushed a copy of API 650 to me, which I was able to read completely prior to the meeting. At the meeting, the city's reviewer started with the building code deficiencies. I then explained to him that the structure in question was not a building, but a tank, and that while certain building code provisions would apply, it must be reviewed as a tank against the industry standard API 650 from which it was designed. It took him a while to understand this point because in his entire career, all he had ever reviewed was residential and commercial buildings (and he was not green engineering, either…he had a masters degree and 20 years in structural engineering, both design and review). I walked him through the design, using API 650 and the calculations as a guide. At the end, he agreed that API 650 was the right standard, but that put him in a quandary because the City of #$%^& had no legal means to use it as part of their code and it would take many months to work it through their system and get it approved by the City Council. I asked him to call his boss into the meeting, we explained the situation, and then I asked his boss if there was some way, any way, to adopt API 650 as department policy for this project (and for my client's site as a whole) since we couldn't wait for formal adoption. With a twinkle in his eye, he said, "It will be our little secret." Then he got serious and told us that he would initiate the process to get API 650 adopted by the city, since he knew my client had expansion plans and this would come up again. This was actually one of my better experiences with the City of #$%^&.
--Winston S. Churchill
thank you for your replys
