steel beam design
steel beam design
is it of importance when designing a beam to give/find the plastic modulus, elastic modulus or you can just use one of them.+ the deflection compared to the permissible deflection(l/360).
RE: steel beam design
With plastic design as opposed to elastic design (both limit states can be applicable) you normally use the Zx and the section (in Canada) has to be a Class 1 section.
Dik
