Pro/E 2001 crashes when using MODIFY command
I am having a problem since upgrading to 2001.
Sometimes when using the MODIFY command in Part mode, Pro/E will crash and just disappear completely.  It happens after selecting a dimension value to modify, typing in the new dimension, and clicking OK or hitting ENTER.
Has anyone else had this problem?  It never happened to me with 2000i²
RE: Pro/E 2001 crashes when using MODIFY command
Yeah,
Every now and again my system will crash like that. When I do a modify, I can not dynamically spin or zoom the part around without risking a "Poof".
Some things ya gotta learn to work around, you might be stuck redefining instead of modifing.
