Linear Actuator remote location
Hey all, I am trying to build a scotch yoke system with multiple sliders positioned along a single rocker arm. The issue that I am running into is finding a good way to elongate my electric solenoid shaft.
I can get a solenoid that will give me more than enough stroke length to rotate the cranks where I need them, but I would like to hook up multiple cranks to this system and have it span about a 1.5 foot length. Any suggestions on a reliable way to attach a longer shaft to the end of a linear solenoid would be greatly appreciated.
I have thought about adhesives, threading both components, and clamping the longer rod on, but I have no idea which will hold up to loads the best and take the least amount of effort.
RE: Linear Actuator remote location
For a simple tubular solenoid, you don't need anything real fancy; low alloy steel, shaped like the OEM solenoid plunger, annealed and nickel plated, should be sufficient.
Mike Halloran
Pembroke Pines, FL, USA
Keith Cress
You haven't given enough detail to assess whether a solenoid actually is a good choice.
At some levels of mass, a number so far not in evidence, other alternatives exist, e.g. door lock motors.
Mike Halloran
@ itsmoked: I will be using an AC solenoid, but the duty cycle shouldn't be an issue. Thanks for the heads up on that though.
I also just looked into the car door lock actuators, and those seem like a pretty decent alternative. Any idea what sort of stroke length I can get out of a standard one? Also how well would they hold up to the load of an elongated shaft?
Keith Cress
The door lock actuators are well adapted to running exactly one thing.
So use a bunch of them and forget the mechanical selector mechanism.
Mike Halloran
