ASME Sec 1 Parts
ASME Sec 1 Parts
Received Boiler proper(Pipe Spools)supplied by a CODE manufacture C/W P4 material supplied as PARTS. ASME Section 1 PG-106.8.1 Marking of Parts lists four items that have to be stamped on the part see listed below. The piping received is under 5" OD (3" OD) so PG-106.8.2 applies are the four items listed below still mandatory or is the part serial # only traceable to the P4 acceptable.
(a) Certification Mark above the word "part"
(b) certified by (name of Manufacturer)
(c) Manufacturer's serial number of the part
(d) year built
(d) year built
RE: ASME Sec 1 Parts
