VBA macro for renaming multiple operations AGAIN
ok so I ran across a couple of posts that had information on this already. 2 yrs old and closed. hoping someone is watching "markrief" lol Looking for a variation on the file that was posted in the others. (RenameOperationsOntSelection) I need it to not ask me for what I am looking for as I already know since I selected it to begin with. What I do need is for it to ask me what I want them to be named. Then rename all in a sequential order adding 1 the number I start with on the information entered. Say WHAT_EVER_I_WANT_TO_NAME_IT_1 is what I put in then it adds 1 to the 1 at the end so the second becomes WHAT_EVER_I_WANT_TO_NAME_IT_2 the third WHAT_EVER_I_WANT_TO_NAME_IT_3 and so on until the last one is reached.
Here's to hoping someone has had the same desire but more vb knowledge.
Thanks in advance
Thanks in advance
RE: VBA macro for renaming multiple operations AGAIN
www.nxjournaling.com
and
http://www.eng-tips.com/viewthread.cfm?qid=303802
Mark Rief
Product Manager
Siemens PLM
from my first post.....I need it to not ask me for what I am looking for as I already know since I selected it to begin with. What I do need is for it to ask me what I want them to be named. Then rename all in a sequential order adding 1 the number I start with on the information entered. Say WHAT_EVER_I_WANT_TO_NAME_IT_1 is what I put in then it adds 1 to the 1 at the end so the second becomes WHAT_EVER_I_WANT_TO_NAME_IT_2 the third WHAT_EVER_I_WANT_TO_NAME_IT_3 and so on until the last one is reached.
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UF.UFoper
Imports NXOpen.CAM
Imports NXOpenUI
Module NXJournal
Dim OPERATIONGROUP As String
Dim NEWNAME As String
Dim m_OperationList() As String
Sub Main
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim theUISession As UI = UI.GetUI
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
OPERATIONGROUP = NXInputBox.GetInputString("Enter Group Name to edit", "Renaming Tool", "PROGRAM")
NEWNAME = NXInputBox.GetInputString("Enter New Name for operations", "Renaming Tool", "MYNEWNAME")
NEWNAME = ucase(NEWNAME)
Dim MainProg As CAM.NCGroup = CType(WorkPart.CAMSetup.CAMGroupCollection.FindObject(OPERATIONGROUP), CAM.NCGroup)
'List all the ops in the program
Dim Opnames() As String = OperationList(MainProg.Tag)
Dim counter As Integer = 1
For Each Op As String In Opnames
theUfSession.Ui.SetStatus("Renaming Operation:" & OP)
Dim operation As CAM.Operation
operation = CType(WorkPart.CAMSetup.CAMOperationCollection.FindObject(Op), CAM.Operation)
operation.SetName(NEWNAME & counter)
counter += 1
Next
msgbox(counter - 1 & " OPERATIONS HAVE BEEN RENAMED")
End Sub
Public Function OperationList(ByVal sTag As NXOpen.Tag) As String()
m_OperationList = Nothing
Dim ptr As IntPtr = New System.IntPtr
Dim cycle_cb_fn As NXOpen.UF.UFNcgroup.CycleCbFT = New NXOpen.UF.UFNcgroup.CycleCbFT(AddressOf cycle_OperationList)
'Cycle throught this view and find every object
theUfSession.Ncgroup.CycleMembers(sTag, cycle_cb_fn, ptr)
Return m_OperationList
End Function
Private Function cycle_OperationList(ByVal camObjectTag As Tag, ByVal ptr As IntPtr) As Boolean
Dim camObject As CAM.CAMObject = NXOpen.Utilities.NXObjectManager.Get(camObjectTag)
'Check if the object is an Operation
If TypeOf camObject Is CAM.Operation Then
If m_OperationList Is Nothing Then
ReDim m_OperationList(0)
Else
ReDim Preserve m_OperationList(m_OperationList.Length)
End If
m_OperationList(UBound(m_OperationList)) = camObject.Name
End If
Return True
End Function
End Module
