Waterjet Cleaning for Coating Removal
If high pressure water jet, 40 k psi, is used to clean the coating inside crude oil storage tank, the metal yield stress is 36 k psi, does this high pressure cleaning affect the weld/metal hardness (say 225 HBN after welding)? does the tank weld hardness have to be maintained the same after welding?
Thanks for your inputs.
RE: Waterjet Cleaning for Coating Removal
But note that in normal sandblasting, the abrasive used is harder than the steel with no ill effects.
airsmybag
