Displacement Discontinuity Between Plates with Bolt Preload and Friction Using Linear Contact
I have two base plates bolted together with preload and friction (see attached) set up with linear contact. When a shear load is applied to the joint there is a discontinuity in the T2 translation between the plates even though the joint should be sufficiently clamped to prevent any relative motion. I have adjusted the friction values, experimented with convergence tolerances, and search distances with no success. However setting the coefficient of friction to zero results in a larger discontinuity (0.0234in vs. 0.0179in). The surface contact is otherwise behaving as expected. Any ideas? Thanks!
RE: Displacement Discontinuity Between Plates with Bolt Preload and Friction Using Linear Contact
This could be a graphics magnification, please note this is linear static analysis, then displacements are small, then the deformed shape is exagerated. Use a scale 1:1 + activate "ACTUAL DEFORMATION", and you will see the real results.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Thank you for your response. That was my initial thought so I checked the nodal displacements of two conicident nodes on each of the top and bottom plates (see attached). While not large there does exist a relative displacement ~.0004in. A similar translation occurs at the edge of the hole. The plates "should not" translate with respect to each other. However I am new at this and maybe I am missing something. Would a small movement such as this be physically justified?
Thanks again!
how are the two pieces connected together ? anything less than a rigid constraint will strain.
Quando Omni Flunkus Moritati
it's possibly due to the way you constructed the model. i've made simple test models and gotten different results depending on how i created the geometry under the model.
if you have clamped the plates together, and Know that your applied load is less than wahtever friction could be there, then you're satisfied that in the real world it won't slide; despite what the FEA shows you.
you know that friction is reducing the displacement, how about increasing it ?
what if you constrain a couple (3) nodes on the interface (equivalence 3 pairs of nodes) ?
